00 srx 700 air box issues & belt squeal
hessracing
Iron Mountain Michigan
hey guys on my 00 srx 700 im not sucking enough air the only time i can pull through the powerband strong is when i pull my foam air box cover off other wise it boggs down when i gun it any ideas? also my belt has been squealing non of the motor mounts are broken could it be out of alignment?
belt squealing is usually from too tight of belt deflection, from either incorrect center to center of the clutches, or wrong shims behind the 3 bolts on the back of the secondary.
