Roller Secondary
KEVIN
VIP Lifetime Member
OTTAWA
I have a Roller Secondary on my 98 SRX
Rollers or worn
What measurements do I need?
Width & diameter?
What about the bolt size?
There are about 20 different roller secondaries out there. What make have you got???
Is there any advantage to running the roller you have? A local guy has one for sale, also says hi tech on the cover. He wants 250 for the complete clutch with it. Not sure if it's a good deal or if I would gain anything with it. Seems spendy
I have 3 of them and they work fine when properly setup. These kits got a bad name in the day, cause duane watt the owner, never gave proper setups or springs out w/his roller kits. They work fine. What helix and spring are on that clutch that's for sale locally?
