Pulse line srx700
danaa
moncton
i had the motor out , and did not make an effort to remember where the lines go , and my pulse line is in the wrong spot , because it wont keep sucking fuel after it runs for a minute . could i get some direction . Thanks
Not Connected In Wrong Spot U Would Not Have Fuel At All... Maybe Pinched Or Split ? Pull 3fuel Lines Off Carb And Pull Cord, See If Fuel Comes Spitting Out .... If So Then Go To Carbs Check Pilots ,
I Bet It Runs Out Of Fuel On Idle ....
yeah but i have to keep holding an air hose to my tank with my hand over it and that blows the fuel threw the hose to the line. but i will try tomorrow morning the fuel lines are unhooked off the carbs not so ill pull it over , but i know for a fact iv got the wrong hoses hooked up . i need a diagram thanks for the help man
motorhead327 said:
Looking down at the fuel pump it goes oil hose,vacuum hose, carb, carb , carb hose in order from brake side to belt side.
10/4 if this is correct then pull fuel line from tank off pump you should get fuel
okay , then there is a hose that splits into two.i think thats the vacume hose . iv got them hooked on the pump right, now i need to hook them up to the motor .
no i didnt get it , thanksfor alll your help . i asked for a manual from one of the other posts , and hopefull it will give em a picture in the maual . but all i need to do is figure out were the line hooks on the crank . and figure out the hose that splits into two were its saposed to go. and again thanks for your time.
