crazzygunner
How is the way to make sure you have enough coolent in a 90s exiter
we took apart the top end and checked it over good new gaskets spark plug boots and opened up blead screw on thermostat and poured abit down the filler and the tank untillit was runing out of bleed screw caped it off gave it a run down trail less then a mile temp light on added coolent to tank went off and i keped addin every time this happened to the fill cap and the tank let it set putin more made it back no light how do i know if it has enough will check tank to see if it went down will that give me a clue if its full
thanks.
Evan
thanks.
Evan
take seat off raise rear of sled, on the rear of the heat exchanger there is a bleed screw, get it up to operating temp and bleed out all the air you can then last you level sled and crack the one at the thermostat, keep the tank full. get all the air out or you could squeek a piston.
			crazzygunner
Thanks alot we will have to do that we tryed it to day and the coolent quit acting up
but its still a good idea to get the air out being this is the first liquid cooled ive ever messed with.
Evan
Evan
