walked out of the woods! need 'technical' advice!
plan is to head into the hills this afternoon for a recon, what tools material would you bring?? i've got the necessary tools to pull apart the chain case, ropes, winch, com along, and maybe a plastic sled to put under the track
phase I
visual inspection of the sled, again did i miss something obvious?
Phase II axle
does the track spin free?
is the drive shaft tweak'd or broke?
Phase III
does the chain tensioner tighten or screw in completely?
Is there oil in the snow or belly of the sled?
Phase IIII
If the chain is broken i'll pull apart the chain case and replace the chain which is most likely bound up at the bottom of the case locking the track up. therefore most likely leaving me with a nice hole in the case that i'll deal with in the garage.
the teeth on my top gear (18t) could be sheared, again pull apart the chain case and replace top gear
broken drive shaft? pack a trail into the sled and prep it to be towed out either tonight or another day?
