Had an issue this week end with this sled, at low rpm takeoff it was backfiring and then ran alright. Pulled plugs they were wet and black cleaned and sled ran fine.
I noticed an on off valve that looks like it is coming out of air box to carbs and is in the off position should it be there is the question? Is there anything else could be causing this. I am not familiar with the sled.
that should be the carb heaters. when it is cold out, run with them on or when there is a lot of snow dust. if it is on in mild temps, it will cause the sled to run ritch.
