Can anyone tell me the differance between stock carbs on a 1998 700 srx and the stock carbs on a 2000 700 srx..thanks
valin
jetting is the only difference.
stolpy123 said:Can anyone tell me the differance between stock carbs on a 1998 700 srx and the stock carbs on a 2000 700 srx..thanks
The primary differance is in the jetting specs...you can see this in the tech section. The 2000/01/02 carb racks also have a Throttle Position Sensor[TPS] that the 1998/99 don't have. You could easily rejet a rack of 2000/01/02 carbs and install them on the 98/99 and leave the TPS off but you would create issues by trying to use 98/99 carbs on the 2000/01/02s that have/require the TPS.
Bob
