Which temp gauge did you install?
KEVIN
VIP Lifetime Member
OTTAWA
Thinking about putting a temp gauge on my SRX
Anyone install one?
Water temp gauge
I installed a daytona digital water temp gauge on my 02 srx !! Hook and loop fastner ! Bought it from Dennis Kirk for 100 bucks !! Works awesome at night has yamaha blue backlight plus has clock and celsius - farenheit function !! You will also need a tee to tie into !! They sell them also !! Really is cool to have when running studs - low snow conditions !!
Where did you connect the temp gauge? I have one I'll put on but where should I connect it so that it shows right?
i installed an autometer on my viper. gauge sits in the dash under the windshield. I installed the temp sender ubit inline immediately after the head and before the collant tank.
My gauge is mounted to the handle bar pad with Velcro ! The sending unit is tied into the return line of the water pump ! You are moving enough water that it really dosent matter where you mount it ! It reacts really quick anyways !! When running on the ice it is a really nice feature ! Plus the clock is pretty cool too !
i installed a autometer on my viper..here is some pics an the t-fiting in he coolant hose
