apex
You should ask this on the www.TY4stroke.com forum, you need to sign up over there as well but you can use the same info as here if you want.
Black ring at the bottom is Rebound
On this shock, the compression is electronic, at the top.
Just below the gold canister (reservoir) is the spanner nut to adjust the spring preload.
