94 vmax midrange bogged cured
Patriot21
Minnesota
94 vmax midrange bogged cured/BOG IS BACK arrggg!
Well after a few weeks, i finally figured out my vmax..... i moved the clip on the made needle up to notch 2 and the midrange bog is gone.... my plugs look chocolate brown so i feel i finally got it.....
just thought i would post this as i know others have this issue
Ok...guys i am going nuts!!!! took my sled out last night.... ran good for about 15 minutes then the bogg comes back.... barely hiting 45 mph and about 5-6k rpm.....no power.....hit full throttle and just bogs......if i let it sit for awhile.....i will get power again..... then just starts to bog....i cant take it!!!!!!!
sounds like its starving for fuel... need to take carbs off and make sure nothing is plugged. if thats ok, need to check fuel pump
