Any Expert Yamaha guys in mpls area on here?
srxman06
shakopee,mn
Are there any expert yamaha guys on here in the mpls area that i can get to look at my viper? Not sure why i have burned up 2 cylinders already this year.
again show uss some picture ...do u run pipe ?do u run stock air box ?anything modify ??
did u started to get trouble after putting those v force and boost bottle ...probably running lean
Amundson Motorsports
I can fix for you. Located in St Paul. Small snowmobile and pwc repair shop out of my home. 23 yrs experience. Tim 651 428-3394
pictures would help with figuring out what is going on. When did each cylinder go out? wot? mid?
What does the plugs look like? Did you check the wash?
Details will help you get the correct answers and get it figured out ;)!
I will get some pics on here later today.Each time it has happened i was pretty much wot(not gripped though). The 1st time it happened a small piece of the ring broke and took out the cylinder and piston. This time a larger piece of the ring broke and caused more damage to this piston and cylinder then the other time and also chewed up the power valve
never seen ring broke ..maybe the power valve hit the piston ring or something like that but only broke a ring hmmmmmmmmmmmmmmmmmmmmm don't think so
Here are some pictures.
