Turbo50Mike
I just got a 2001 SXR700 (That's SXR not SRX), and I want to do all of the routine stuff before I hit the trails.
Since I plan on doing quite a few miles this year and it already has about 2500 miles on it, I want to replace the Hyfax.
Can anyone give me the info on how to do it. I did a search on this site, but no one was specific about how to do it. On another site they say you have to make the slider window a little bigger to get them out, but that may have been on a SkiDoo. Do I need to do this on the SXR?
Also, does the SXR have the same Hyfax-eating characteristic of the SRX?
Thanks,
MJB
Thanks,
MJB
notching not requiredd if its a stock track, check out the Tech Area...lots of info there...here is what you are looking for http://www.totallyamaha.com/snowmobiles/aaTECH/changing_your_slides.htm
Turbo50Mike
Sweet.
Sweet, thanks...Just what I was looking for....What controls the alignment of the track, the two "straps" that are pictured? (Pic 2 - #25 & 26)
MJB
MJB
no , that adjust the fornt limiter,the two #95 is the track adjusters in the rear...adjust track tention and alignment....
Turbo50Mike
Ok. I just want to check one thing....In the description it says to loosen Pic 2 #25, & 26. If the adjusters are #95 & 96, is that a misprint?
MJB
MJB
sorry that is a misprint
