Anti-stab wheels viper mountain
SxViperMountain
Sweden
Should a Anti-stab kit be mounted instead of the limiter strap axle on a viper mountain? is'nt the mounting point a bit far back then?
Im thinking of making my own anti stab
What dimensions should i use on the wheels?
anti stab kit mounts where the rail tips are bolted/riveted on. They prevent the track from spearing the rail tips, I can measure the wheel size, should be about 2".
ok, do i have to cut the tip of the slide?
should i use the plastic tips at the end of the slide?
is the hole from the rivet the right place where the axle should be mounted?
Does anyone have pictures of anti-stab on a viper?
