1985 phazer oil pump cable adjustment how?
Jay13
Ohio
How do you adjust the oil pump cable on a 85 Phazer? Is there a measurement for the adjuster that is mounted to the carb? Can someone walk me through the procedure?
Pull the oil pump cable housing up (where it attaches to the plate next to the throttle cable). There should be .83 to .91 inch clearance between the cable end and the adjuster.
