01 sxr 700 stator good or bad?
hereismylife
Pa
Website
www.hereismylife.com
I read and read...
I am working in my garage which is at about 20
Just want to make sure this is right?? spec is .36 - .80 ??
I am getting .9 on all 3 white wires does this mean stator is bad?
Also at idle all 3 wires reads 4.5-5 volts which is 14.7-15 volts altogether.
I think the spec is peak voltage should read 18 - 17 volts at 1800 rpm?
Is the stator good or bad?
Sled runs great with no engine problems or light problems.
Huh?
I guess I'm just wondering. If the sled runs great and has no problems why are you testing the stator? You guys got any snow down in PA? Awesome riding here right now and my garage is 68 degrees!
Madmatt
??? I was wondering the same thing? I have had junk stators ohm out IN spec. I think you are wasting your time. You will know when its bad or if you need to test it. (Cut out at high rpms , NO spark, intermittent spark etc.....)
Well I am testing and testing...
Trying to get all handwarmers to work...
I worked on this all weekend and today....
It is either stator,regulator,or cdi box.
I just wanted to make sure my stator is ok so I can go to the next item on list.
