Bravo 250 belt deflection?
toddmod
upstate NY
I have a Bravo 250 I ride in the woods. The belt deflection is excessive & can slip the belt at low speeds. I have had the primary apart & installed new weights. I have removed the secondary & removed material between the sheaves to allow the belt to run higher. The belt is a new 820 & the motor mounts are good. I'm either thinking of removing the engine & modifying the motor plate or searching for a belt that is a little wider. Any suggestions? does anyone have the same problem? My Bravo is an 89.
