sweeet_2012
Will handlebar risers taken off a 2006 apex fit my 2002 viper? Its just a 2 inch block. My dad took it off his apex and I want to put it on my viper.
My guess is yes, but it will only take you 5 minutes to find out for sure. Your cables should be ok, just be sure to swivel the steering back and forth and check that there is enough slack in them.
Let us know what you find.
i have a total of 5" on my standard viper with Apex/Attak bars. The apex bars are 2-3" shallower than the oem viper bars, so overall I'm 2-3" higher than the orig height. Rolling the bars forward a little also helps. It's a perfect height with the seat riser.
I believe the mtn vipers have longer cables and are able to go a little higher with stock cables than the std viper.
2" block is fine with stock cables on a viper. you have to do a bit of re-routeing but they work fine. brother has 2" on his 02 viper and we just put a 2" on dad's 2005 sxventure.
sweeet_2012
Alright I will have to try it out
