Lube points
greg
Ajax/Apsley Ontario Canada
In need of more of your wisdom.
On a 2000 SX700R, is the jackshaft bearing behind the secondary clutch supposed to be greased? I hate to even bring this up but my ski-poo had a nipple behind the secondary clutch for greasing this bearing.
I can't see any nipples near the bearing to grease; I don't want to take the airbox out just to find out that this bearing doesn't need to be greased.
Thanks Greg
There is no place to grease on those bearings. You could remove the bearing, take the seal out and pack grease in by hand but otherwise they are sealed.
