Hyfax wear
Yaaamaaahaaa3
Harrison, Ohio
I noticed that my hyfax is wearing in the rear and usually wears at the bend. Is this normal depending upon material or do I have to make adjustments?
Do a search on hyfax wear,,, they wear to a point, up to 50%at some points then stop.... There are many things to reduce wear, not running the track to tight, over sized wheels, extra wheels, but best thing you can do is not ride it in low snow conditions......
