gmcdunnah
any of you racing guys ever put a dyna launch box hooked up on a button on any of your prostocks??? anyone wanna shed some light on it thanks!
valin
I have a Dyna DRL-300 setup on my trail sled right now.
gmcdunnah
.how do you like it valin? does it load up any?
valin
I've only played around with it a little bit. It loads up quite a bit. You would not want to have to hold that button for very long.
gmcdunnah
very hard hooking it up?
valin
No, quite easy.
1 wire for tach signal.
1 wire to kill switch
1 wire for ground
1 wire to power
Just install a button or switch to either the power or ground so that it is only activated when the button is pressed, and you're in business.
I will sell mine if you are interested. I bought it in case I was going to run on the grass, but am not going to do that anymore.
1 wire for ground
1 wire to power
mattyg1405
ive heard that before lol.,..valin said:I bought it in case I was going to run on the grass, but am not going to do that anymore.
gmcdunnah
pm me a price if you would valin...thanks
valin
pm sent.
