HELP with 2002 viper!
herluf
corner brook
When I Start The Sled, The Speedo And Rpm Guage Comes On....immediatley It Stops Working And The Speedo Goes Blank....this Continues Going On And Off As Long As The Machine Is Running......no Problems With The Headlights, Tail Lights Or Running Order Of The Machine...just The Dash!! Whats Wrong Please?????? Pm Me If U Have An Idea, Thanks!
Do a search for "harness" on this site. You likely have a wire harness rub-through under the engine. Another possibility is that the plug in the back of the gauge is not fully seated (be sure the rubber seal is pressed all the way in as well).
You can disconnect the wire harness near the hood hinge. Release the bend down clamps along the harness. Tie a string (to pull it back in), and pull the wire harness up by the coolant tank. Then you can inspect the wire loom closely and repair any damage.
I merged these 2 threads - site rules - most use the New Posts button and will see this thread anyway
check the battery. Mine did that as well, and would go on and off as it charged itself. About 30 miles in to a ride, it has enough charge to not cut in and out anymore.
