billbies
Needs some pics of SRX with these skids hopefully with pro x but others will help I have a pro x skid I am hoping to install this weekend and need real world measurements and some good pics of side would be much appreciated
kozal01
I have an IQ skid in mine, similar to the Edge from what ive been told. here are some pics. as far as measurements i got them from http://www.jbshocks.com/tech.html here are a couple pics of mine
billbies
any chance you would be able to take close ups of your mounting points in comparison to original holes
just a closer pic with no snow on tunnel
Thanks again for those pics I am just trying to get as good of an idea as i can
What did you use for spacers?
kozal01
billbies said:any chance you would be able to take close ups of your mounting points in comparison to original holes
these are probably the best pics i have for what you want, my sled isnt here with me otherwise id snap some new ones for you. for spacers in the front i made up 2 aluminum plates at work that i bolted to the inside of the tunnel and then drilled the skid mounting hole through them and through the tunnel. for the rear i used large washers
in the first pic you can see the front mounting bolts up near the footwell. the IQ and edge only use 4 mounting locations instead of 6 like the pro action. the rear mounting location is slightly higher and to the rear of the original mounting location.
WNYViper
98 with an Edge skid... I dont have any close ups, have since sold the sled...
