Vmax Al
Is it unusal to have very little to no fuel in the carbs when you take them out for cleaning?
I am use to a little fuel spilling when I pull the lines and I always put a golf tee in them while I work on the carbs on the bench, but this last time I disconnected them and not a drop, is it a sign of something more serious?
Thanks,
Al
Thanks,
Al
Did the machine sit for a few days before you pulled the carbs to work on them?
Vmax Al
I haven't turned it over since spring. It's electric start and I pulled the battery. There is a small amount of fuel in the tank, but I will be draining that for fresh before trying to start it.
Ok that's why fuel evaps over the summer and storage periods thats common no issues mine are like that all the time..Vmax Al said:I haven't turned it over since spring.
Vmax Al
That's what I figured, just different to me to have zero.
The carbs gurgled a little when I had them upside down, but not near like my other 700, but I also had that started and then decided to clean the carbs in that.
Everything looked clean at first but that slim can be deceiving when dry I guess because when I hit it with carb cleaner the liquid came out brown, not clear like the cleaner.
yea sounded like they needed it,mine has a little brown crap liquid in it and that's it.
