what is this.
snopax
Wisconsin
Noticed 2 rods in the rear of the skid, one on each side. They have blue anodized gnurled adjustments. The sit at a slant going from the bottom to the top of the skid. Anyone know what they are. I'll try and get some pics Sunday. Adjustable control rod? What is it for?
So how does adjusting them change the way the sled handles. How do I get them dialed in. They are the bender adj rods.
the larger the gap you leave on top the more weight transfer you will get to the track. but this also changes the how much rail coupling(both shocks working as one) you have and also softens the suspention threw most of its travel. more transfer(larger upper gap) will mean better traction, lower ski pressure when on the gas, and better handeling in small stutter bumps. less transfer (smaller upper gap) means more track spinn, more ski pressure and stiffer thru out the whole travel. with adjustments to your transfer rods, the FRA and limiter straps theres alot you can do to make the sled handle alot better and more to your riding style. just takes time and testing to figure out what you want.
