Elec. start doa
ronhrfd89
Roscoe
Can anyone help? Electric start on my '97 vmax just stopped. Battery checks at 215 cca. Both 10a fuses are god on each side of relay. Starter seems to work correctly if you remove it and jump it on the battery. I am out of ideas.
Do you have power to the solenoid? Should have 12 volts on the one big post and 12 volts on the small post when key is turned.
