Start The Sled Runs Ruff Headlight Dim,tach.dash Lights,fuel Gague Not Working Unplug A Headlight Does Not Matter Witch One Runs Graet And Everything Else Works Then.
Tried Voltage Reg. Traced Wires Came Up With Nothing Could Use Some Imput Please
Check the wiring harness that runs under the motor for rub through.
Tape and re-tape exposed wires and insert the harness into plastic wire loom from auto store. Permanent fix
mattyg1405
check the stator... i just had the same problem then it stopped i havent checked my stator yet im gonna check for a rub through first if not... you know its got to be the stator
BIGRAM101 said:Start The Sled Runs Ruff Headlight Dim,tach.dash Lights,fuel Gague Not Working Unplug A Headlight Does Not Matter Witch One Runs Graet And Everything Else Works Then.
Check FAQ for wire rub-through, harness R&R and repair tips.
