I have a MM 700 and i cannot find throttle cables or extentions for the 4'' riser i want to put on. Would sx viper 700 cables be longer than the MM 700 cables?
the 03 mtn viper cables will get you there, not the sx ones.
That is what I had to use. Worked out well.
Your brake cable worked too? How much longer are the mtn viper cables than the mountian max cables
Get an Rx1 brake cable. They are longer. I know a guy just outside of Saskatoon who would have one. Pm me and I'll give you his contact info.Russell said:Your brake cable worked too? How much longer are the mtn viper cables than the mountian max cables
