lilnotts
I'm working on a 88 Snoscoot for a friend at work. It would run at all when I got it, so I cleaned out the carb as most of the jets were plugged up as it sat with gas in it. I also found the the stock fuel pump would no longer pump. I had a spare old Mikuni fuel pump from my TNT so I tried that and it would start up and run but not well as it would sometimes run fine and go to full throttle and then bog down. I had also found that this spare old pump was leaking fuel out of a vent so I figured that I must need a rebuild.
I ordered a rebuilt kit for my spare to have on hand and a new universal single in single out fuel pump for the scoot. Now with either pump it will not run. If I put gas in the cylinder it will run. With the hose off the carb it will pump fuel through the hose. I went through the carb again to make sure I did not miss anything. I even rigged up a gravity feed system to feed some fuel to the carb and tested the float valve and it works fine. Which makes sense as the bowl is always full whenever I take the carb off as I have done it a few times looking for something that might not be working properly. It almost seems like its not sucking the fuel through the carb into the cylinder. I'm now at a loss of what is wrong. Any ideas?
