help with adding 3" riser to 02 MM/ parts fiche has multi choices
TJ500
Lockport, Manitoba. Canada
I know this has been flogged to death but I'm about to order new/longer 2003 Mtn. Viper cables for my 2002 Mtn. Max so I can add a riser... The fiche has listed two of each cable to choose from for throttle, oil, parking brake and hydraulic brake hose.... Which of these are the longer of the two for each?... I just won't assume the more expensive is the longer ones...
any help is appreciated... tj
