VIPERDON
I Have A Charging Issue With My 2002 Viper Er. The Headlights Go Dull,and Go Bright Occasionally, The Gauge Blanks Out, Then Comes Back On And The Battery Drains Completly. I Recharge The Battery,reinstall It, Check The Voltage With Engine Running, Reads 13.8 Volts.seems Fine. Could It Be A Stator Issue? A Broken Wire?
Where Should I Look?
Sounds like a wire has rubbed thru somewhere. Most likey under the motor. Use the search tab above. There lots of info and tips on this subject.
VIPERDON
Found The Problem, The Red Battery Wire To The Electric Start Motor Was Chaffed On The Right Front Engine Mount. Thanks For Your Help.
