viper chaincase
NHMM700
New Hampshire
Just changed a front heat exchanger on a viper and when putting chaincase back together seemed to have a brain cramp on bottom gear. not sure if i have in right way. I have the large spacer on jackshaft then the bottom gear with raised center facing outwards towards cover then bolt. seem to line right up with top gear and chain looks straight. but when i put bottom gear on it didnt look as if it completely seated on splines of jackshaft. Anyone have and pictures of correct order.
Thanx Dan
Larger collar on smaller sprocket. Raised side of bottom sprocket towards track.
