Heelclickers
phorton22
iowa
Try to keep this as short as possible. Just purchased a 98 srx with 1200 miles. It has been rode very little since 01 - few hundred miles maybe.
Anyways, got it out for a few minutes today and after a few runs up and down a field a could smell the belt. Both clutches were hot to the touch.
I have not have either off and just by visual I can tell you it has heelclickers with red spring, 4 washers under bolt. Rollers are larger then stock but cant say exact size. Stock helix with with red dot on spring on secondary.
Engagement is about 4200 and I didn't open it up to see shift rpm.
So, any guesses on problem with out more details and what is everyones thoughts on heelclickers. I had the identical sled with the popular 8dn-20 set up and loved it. So in my mind I dump current set up and go to a 8dn-20 set. Or is the performance of the heelclickers better???
I trail and river ride only.
Thanks!
