SRX Chain
Thrustie
Ontario
Well I went to put a brand new Yamaha chain on my SRX I purchased last fall to find out that it did not line up with the sprocket at all. It was almost a full tooth off. This SRX I purchased has a mechanical reverse on it from I'm guessing a viper or something? Would this explain why this OEM SRX chain does not fit properly or is this a wrongly packaged chain? I had no idea that I would need a different chain for my new SRX with reverse....GRRRR
Thanks in advance guys.
I think you mean the chain is too wide?? The newer chain & gears -the reverse setup- is probably 13 wide & you might have bought a 15 wide srx chain.
