3wheelerdude
Alright, my first post!
This, new to me 89 Ovation has me scratching my head.
Its got a '99 engine in it, and runs pre-mix.
It will start great, then when at about 1 third throttle it will bog down.
The plugs are on the white side, so I beleive it is running lean but does not explains the bog.
I had the carbs appart(that weird looking dual/single carb) and everything looks good. New plugs, drained fuel tank and a fresh mix of 40:1.
I also took the fuel pump appart and again it looks to be perfect.
Fuel mixture screws were set at 1 turn out when I got it, and I changed that to 1.75 and 2 turns out while trying to tune it with no results.
Anyone has an idea???
Joe
Joe
how we're the plugs you took out when replacing with new ones?
Maim
Super Moderator
have you cleaned the primary clutch lately? debris and dust will build up and can cause this.
need to check the crank seals for air leaks for the lean problem.
3wheelerdude
The plugs had a black/dark brown ceramic, with the tip of the electrode being withish. I am not sure this indicates a lean condition, as usually the ceramic will be with and not only the tip of the electrode.
And no I have not checked the clutch as I though it was engine related, but if you say the primary might cause these symptoms, I will definatly have a look at it.\\
Thanks guys.
Thanks guys.
Maim
Super Moderator
weak primary springs do funny things. only chased one myself for 2 years before i found it.
Mikuni VM-32/34
Throw that odd & funky "Teikei" carburettor in the trash can and put in an ordinary Mikuni VM-32/34 instead.
The engine will run like a champ
3wheelerdude said:This Ovation runs pre-mix.
I had the carbs appart (that weird looking dual/single carb) and everything looks good.
Anyone has an idea ???
3wheelerdude
If I can get my hand on an ET 340 carb with intake manifold, then I would replace the carb, but for some reason, I dont think thats the problem.
- I took the primary appart and the spring without tension mesured 3 inch. Anyone as the specs for this spring, as I would like to figure out if a weak spring is the culprit.
3wheelerdude said:I took the primary appart and the spring without tension mesured 3 inch.
Anyone as the specs for this spring ?
I do not have the specs for the spring when it is NEW. *sorry*
But this picture is of the stock "GOLD" spring from my daughter's Ovation...
It is slightly less then 3"
3wheelerdude
Well thanks alot Lasse. Its the same height as mine, and mine also has the gold marking. So I can eliminate the spring as a potential problem.
Now could the secondary cause bogging at higher speeds...?
Update :
I have done a little tecnical digging...
...and the "GOLD" YPZ clutch spring should be 73.40 mm when NEW !!!
UPDATE :3wheelerdude said:I took the primary appart and the spring without tension mesured 3 inch.
As I would like to figure out if a weak spring is the culprit.
3wheelerdude
Lasse said:UPDATE :
That sounds about right doesnt it? It sits at almost 3 inches, as per picture, and 73.4mm converts to 2.88 inches.
Clutchburner
3wheelerdude said:Alright, my first post!
Joe
Im having the same issue. Did you figure out what happened?
Throw that odd & funky "Teikei" carburettor in the trash can and put in an ordinary Mikuni VM-32/34 instead.Clutchburner said:I'm having the same issue.
Did you figure out what happened ?
3wheelerdude
Clutchburner said:Im having the same issue. Did you figure out what happened?
Yep, figured out that the jetting between 89 and 90 models is completly different. So this 89 Ovation had a 90's carb. Changed the jets from 170's to 140's and it runs like a champ.
Still running the oval crab in 3 different ovations, and they all run good.
Clutchburner
Ive had the carb apart so many times and tried countless things and after about 30 minutes the thing just wont do anything but idle unless i shut it off for a few minutes but even then it doesnt run long.
Here is a guy that have the same problem with his Ovation: http://www.totallyamaha.net/forums/showthread.php?t=78586Clutchburner said:I have had the carb apart so many times and tried countless things and after about 30 minutes the thing just wont do anything but idle unless i shut it off for a few minutes but even then it doesnt run long.
