Anyone use one of these kit's?
Was hoping to improve the fuel mileage on my 96 vmax 600,only getting 8-9mpg.I know they are known for bad mpg but I'm sure it can do better
thank's.
thank's.
had it on my pol 500 . works great . had to stud after that
works best with a ex themp gauge to have it set the best as temp changes
l have them on my vmax4, i get about 10-15% better mpg as well as a better thottle responce and a small performace increase, Dial a jets are great if you run pipes as they only supply the fuel you need.
Settup is simple enough with basic DIY skills and tools, you need to drill and tap one or 2 holes per carb depending on carb type.
lve fitted dial a jets to a couple of MX bikes aswell. They are well worth it espesially if you have engine mods and ride in varing temps/altitute
ever try these? am interested in this as well
RB2001SRX700
Lifetime Member
Can you still buy the kits or do you have to make them yourself?
trutrent
Thunder products .com
Yamahasrx700
I have a set from my 1995 VMax 600. I would be interested to let them go.
brandenj09
im definitely curious about this, 10-15% improvement of gas mileage would be worth it.
