I own a 2002 SX600R with about 3k on it. Great sled, but it's developing an intermittent bogging problem. I've noticed when trail riding after letting off the throtle for a turn and then getting back on the throttle it bogs to a stop. Once the revs drop to an idle it will take right off again. Does this sound like a TORS issue to anyone or a carb problem? Many thanks.
almost sounds like a clutch issue.....
take your clutches apart, clean and replace any worn parts!!!
Yes, that sounds like a TORS issue for sure. You can disonnect the TORS switch to see if the problem goes away. If so, with the proper adjustments you should be able to get it working correctly. If you do a search you'll find tonnes of info on it.
abumpa
I have the same sled and had the identical problem last year. Replaced the TORS switch at the carbs and all was well.
