94 vmax primary
ottawaair
Grand Haven, Mi
other than the different style bushings, the short cover & spring, what is the difference of a 94-95 vmax 600 primary to a srx primary. I have a like new 94 primary, just wondering if it could be clutched right on a srx?
rollers on the 94-96 have a different inside diameter and pins to match. rollers wont interchange. also, the 94 spiders were known for breakage and the issue was addressed in 95 and up with a slightly different spider machining.
Would a person be able to use this clutch on a newer vmax or srx. The rollere are in there already, could I put a set of say 8dn-20 or something like that & work as it should.
it will work. direct bolt on. could probably swap covers as well. just be aware if the spider issues. almost enough problems for a recall on the 94 clutches. the way yamaha ended up handling it was when it happened, it was replaced at no cost. i had 2 go on my 94, in 94. they were updated in 95. never another problem with the updated spider.
