JERSEYJOE
Ok I have read BETHEVIPERS article on this but I have a few questions.
1. I have installed a Pioneer wide kit with outer heim joints, Viper trailing arms and spindles. What should i set the center to center width to? A stock Viper looks like 42 inches, but the wide kit adjusted all the way narrow is about 43.
2. Should the camber be slightly positive at set in height?
I would go with 0 camber with weight on sled.
I would narrow the sled as much as you can if you trailer it. sleds are 42 for a reason, with wide skis, even 42 is a pain sometimes.
