Which oem plastic skis fit an Exciter II?
i just mounted ski doo precision skis off a 05 on my 85 maxx the struts came off a 91 exciter II all that was needed was two shims per ski
The only "OEM" would have been the original Yamaha branded USI skis and possibly the later GYT skis.
Check the catalog sellers and Richie Rich here for aftermarket.
MikeRWK said:
Anyone know?
if your sled has the tss it should have the same spindles as my '94 phazer II. look a few post below your post i am buying plastic skis for mine. two good options are either kimpex(which i'm doing , but more expensive) or camoplast. all the post talk aboutprice and a contact number on the last reply. loking between 240-270 for skis, saddles, 4" carbides, and mounting hardware.
brian
'94 phazer II
'05 sx venom
'75 arctic cat pantera 340
'01 z 120
Take a look on this site as this topic has come up several times; I have used several sets of new RX-1 skis, slightly modified the saddles, to fit the TSS suspension. They work great.
I did some fab work and got SRX skis to fit. RX-1 skis are easier, but the SRX skis will work too.
