Exciter II with blown tss struts, upgrades?
MikeRWK
Canada
My struts are so bad on my sled its dangerous to drive, are there upgraded struts available? id like something stronger since im a pretty big guy.
I have 4 TSS struts off '94-'96 Vmax 600 sleds if those would work for you. I really have no idea. I am sure they are probably longer.
im not positive but i believe only the vmax xt had longer tss struts the rest were the same length the vmax 4 struts r stiffer for a heavier sled
The front Struts from the 1994-96 Vmax 5-600cc sleds will give you 2" more travel ! You need the longer shock covers, springs and aluminum knuckles along with the struts. You can find them fairly reasonable on E-bay, any parts forum or salvage yards ! I bought a set of brand new(rare) Genuine Yamaha GYT Kit struts off of E-bay that were an upgrade for the Vmax 5-600 sleds with adjustable dampening, rebound and slightly longer travel for $75.00 ! Yamaha part # SMA-8CA91-10-00
The 94-96 Vmax 5-600cc sleds had 7.2” of travel although a inch or so was used up in set in or suspension sag (Bender made a kit to get back and use this lost? Travel. The struts would work for the Exciter, Phazer II’s or any Yamaha that had enough clearance for the longer Strut covers. I’m not sure on the Vmax4 how much travel they had ?
Yamaha had a T.S.S. GYT Kit that had adjustable damping along with adjustable preload. Yamaha part # SMA-8CA91-10-00
