hey guys, just got the 03 rx1 skid in my 01 srx and things dont look so good, i got the front backets flipped and i also added spacers, when the sled is sitting on the floor the transfer rods are at 50/50 and when i lift the sled off the ground its 0 on top and 100 at the bottom, the sled sits 1" lower then before, the rear spring is set to the max, please help me
Post a pic if you can. Will be easier for us to help you.
I'll post some pics later, I have the limiter straps all the way tight and the front still lower then the back by 3".
i think i found the problem, the front w arm is upside down compare to my srx, is that normal for the 03 rx1???
