Heelclicker 40-10s thats been weighed
Stirllan
Sweden
Hi there, got a hold of a scale at my work that could weigh as little as 0,000grams and was recently calibrated, so why not try the HC arms?
1st arm weigh 51.4853g
2nd arm 51.4724g
3rd arm 51.5120g
I assume w that little difference it shouldnt be a problem putting them on?
(someone who knows their clutches could answer plz ;)
dont know where to put this but if its in the wrong category plz move it :)
Yours are closer then most.
Seen some out a lot more then that. run em & don,t worry about being out as there are 3 weights working together & being out a bit won,t do anything.
exaxctly what turk said.....use them as they will be fine. your set is the closest that i've ever seen. my bro's set has a .5g-.6g difference between one another flyweight!! i can't remember the differences in my 45-7 weights or my 40-10 weights, but it was at least .3g.
great, thanks a lot guys!
and another thing, could you help me w a clutch testing procedure? like what to test when i change that and so on, 1g in the shoulder, try wot and dont have a bog? try 1g in the top then wot and look for that thing? when to feel if the clutches are warm? if they are, what to change? and so on
would appreciate it a lot! someone else is probably wondering too ;)
Been beaten to death & it,s all in the tech pages in the clutching section.
