Bar end installation
gf7duster
Ontario
Just bought a set of bar ends, is it as simple as cutting the end out of the heated grip and pushing the bar end in and tightening it up?
Definitely don't just cut the end off, I tried to follow instructions similar to what richierich said (I forget exactly what they were) and still ruined the grips.
Good luck.
a step bit works great for this application. simply drill into the hole on the end of the grip until the bit hits the metal of the bar ends, clean the excess grip rubber with a knife or dremel and install the ends.
one issue i have run across on the several sets i have installed is the larger diameter of the ends vs the inside diameter of the bars. some sanding on the bar ends may be needed for fitment.
