helmut
does anybody know the part number for the drive axle bearing for a 98 srx im looking to find an alternative bearing rather than right from yamaha?? Im short of time and wont have a dealer to stop at! If it is a 6205 brg i can get it at an auto parts store!
FuzzButt
Which one are you looking for the one in the chain case or the speedo take off side?
helmut
speedo side
ottawaair
just make sure the one you get has rubber seals. I know of other brands using a metal seal on thier sealed bearings & they don't last long down in the snow. The yamaha bearing is a very good unit.
RK-SXVIPER700
If its the same as a Viper. Fafnir #YAE25RR, $19 at local bearing dealer and was in stock!
Stephfg
like RKSXViper700, I use Fafnir or Timken for that. I posted this in another thread:
I use Timken or Fafnir collar lock for that and the jackshaft. I think it's about $24. this is the part number for the drive shaft: rae25rr . fyi, the one for the jackshaft is rae25rrb (rounded outer race). Make sure you get metric ones... the other appears to fit, but it's a little too big and comes loose (learned by accident). With the collar lock, you don't have to worry about the set screws letting go. I ordered mine from the local Canadian Bearings store, but do a search online for other dealers.
