sledheadjeff
im thinking of a summer project, and my thought is to put a skid from a 1998 mountain srx in my 1998 srx, will the skid bolt right in or am i better off putting rail extensions on my 121" ?
or any other suggestions?
sledheadjeff
.. anyone?sledheadjeff said:im thinking of a summer project, and my thought is to put a skid from a 1998 mountain srx in my 1998 srx, will the skid bolt right in or am i better off putting rail extensions on my 121" ?
not a direct bolt in, you will need some drop brackets from the rear of either the srx mtn or any 97-99 mtn max, as well as a tunnel extension and misc.
what track are you planning on using? the mtn srx used 8t drivers vs the 9t on the 121 models.
the mountain srx used 9 tooth drivers like the rest.
sledheadjeff
well is it 8t or 9t??
8t sprockets, i just went out to count my bros mountain srx, also its mounted in the same location as the 98 srx. with lugs like those its an 8t.
i dont know, maybe its just on mine because the part numbers appear to be same. maybe someone else with a MSRX can confirm
srxhair
98 MSRX came with 9 tooth drivers with the 1 1/2" track, If you got the optional 2" track you needed 8 tooth drivers.
sledheadjeff
ok thats good to know, but now just to confirm! would this skid bolt right into my srx?srxhair said:98 MSRX came with 9 tooth drivers with the 1 1/2" track, If you got the optional 2" track you needed 8 tooth drivers.
sledheadjeff
some people tell me that it should fit and others tell me that i will need to make a drop bracket of somesort.. ???sledheadjeff said:ok thats good to know, but now just to confirm! would this skid bolt right into my srx?
