have a 2000 SXR 700 that i can't get to idle or run right for that matter. when i first start it on full choke the idle jumps to around 3500 grand, enough to engage the clutch. after a few minutes and getting the choke off the sled will eventully bog down and die out if i don't keep it running with the throtle. ive run it for around 1/2 an hour just beating it around the house and it back fires quite a bit. as soon as i stop it wont idle. just dies out. any suggestions would be greatly appreciated.
Carbs Carbs Carbs, need cleaning. Pilots, mains, pasajes.
Do a search here, you will find all the info with pics...
Oh by the way
Nick
Oh by the way
Nick
Yes, clean the carbs before you burn down that engine!
