How much pressure should a stock 700 Sx have?
NORTHMANSX
are you talking compression? it should have 125psi to 135psi depending on the tester you use. as long as all 3 are within 5 lbs of each other, you are fine.
if you have a thin headgasket in place the compression will be higher than stock.
When you seperate the stock gasket into three gaskets, what compression would each gasket give?
NORTHMANSX
can't say forsure but i would imagine somewhere around 5 lbs each layer
