Hey guys,
I have a 2001 SXR 700. Last night, we rode for about 3-4hrs, and about 1hr into the ride, the temp light started flickering and then it stayed on. This was spurratic throughout the ride but there was a period of about 1/2 hr where it stayed on. Then, today, we went out for only about 2hrs and the temp light flickered but didn't stay on. Also, the oil lght started to flicker. And yes, the fluid levels are correct.WHAT THE HECK IS GOING ON HERE ??? I recently cleaned the carbs and checked the wiring harness too...didn't see anything noticeable. Has anyone came across this before?
yamyrider
sounds like wiring harness to me
Thanks....should I peel it apart up by the bars all the way to under the motor, or just go right under the motor? Also, is it still rideable the way it is or would something catastrophic happen if it is only wiring rub-through.
