Bad motor mount or not?
Yamablue
Ham Lake, Mn
My motor mount isn't ripped apart, but is it OK for the rubber bonded to the little leg on top to tear apart. Seems like I can pull up on my motor fairly easily and it will come up about a 1/2 inch. I've had a history of going through belts and the alignment hasn't been too bad. Clutches run hot with pretty much everything I've had in there. I have the torque stop on the carb side, but have an SRX limiter on order hoping that will hold it better.
Sno-Tek makes some harder rubber ones, wondering if I should go that route.
