Clutch/ gearing / track question
HD RACING
MOTOWN
I have Turks clutch recommendations parts ready to go in but not the 22-40 gearing or head gasket mod. Will the clutch kit still be a huge improvement? Didn't want to do the head gasket due to crappy gas at some stations. I didn't do the gearing due to still having the stock track. Any advice? Also I assume the engagement ships go on the spring but what side? And lastly can anyone explain twist on the helix? Thanks in advance.
The secondary and helix have holes in them and are numbered. A 70 wrap or twist will be hole 1 on the secondary and hole 6 on the helix. Not sure on the clutch setup you are using so can't help you there. The engagement shims go under the spring.
